1 - 9 of 9 Posts
I don't think this method is limited to just an 08. I bought a 6$ pipe fitting at Home Depot and grinded all the sides down until it could fit right in the pinion nut spun it off with a vice and huge channel locks and some elbow grease, but I think big vicegrips would be better!
The pipe fitting was I think 1 1/2 x 1 1/4 don't quote me bring your diff in just to make sure the pipe fitting slides over your pinion gear as it does in the picture! Figured I would share this since I couldn't find any other tools to work.
1 1/2 x 1 1/2 square tubing, and a large pipe wrench works good too, that's what I use. almost all of these lock nuts are the same size on most Honda atvs.
Discussion Starter #3
All that I could find at Home Depot to work was that pipe fitting but also great to know! Thanks. And I checked local hardware / Napa stores near me with nothing.
if anyone ever needs to buy the ring and pinion set , the after market suppliers will sell you the tool for the pinion retaining nut for $20 added to the cost of the ring and pinion
they really are not that expensive to buy , $23.99 and free shipping is hard to beat
Honda ATV Pinion Bearing Nut Tool 60mm TRX 250 300 350 Fourtrax Differential | eBay
That fit a 420 too?
Racksdeep, that's good info on the pipe fitting! I like to make tools unless the ready-to-go ones are cheap!
Discussion Starter #6
Did not know that, but still saves you an extra 15 bucks or so and the wait for shipping.
Racks' , there is no extra $15 = shipping is free
Jeep , 420 is in there - here is the list of bikes that use that exact same pinion retainer , I'd bet it also fits other bikes :
1985 ATC250ES A FINAL DRIVEN GEAR + REAR AXLE SHAFT
1985 ATC250SX A FINAL DRIVEN GEAR + REAR AXLE SHAFT
1985 TRX250 A FINAL DRIVEN GEAR
1986 ATC250ES A FINAL DRIVEN GEAR + REAR AXLE SHAFT
1986 ATC250SX A FINAL DRIVEN GEAR + REAR AXLE SHAFT
1986 TRX250 A FINAL DRIVEN GEAR
1986 TRX350 A FRONT FINAL GEAR
1986 TRX350 A REAR FINAL GEAR
1987 ATC250ES A FINAL DRIVEN GEAR + REAR AXLE SHAFT
1987 ATC250SX A FINAL DRIVEN GEAR + REAR AXLE SHAFT
1987 TRX250 A FINAL DRIVEN GEAR
1987 TRX350 A FRONT FINAL GEAR
1987 TRX350 A REAR FINAL GEAR
1987 TRX350D A FRONT FINAL GEAR
1987 TRX350D A REAR FINAL GEAR
1988 TRX300 A FINAL DRIVEN GEAR
1988 TRX300FW A FINAL DRIVEN GEAR
1988 TRX300FW A FW FRONT FINAL GEAR
1988 TRX350D A FRONT FINAL GEAR
1988 TRX350D A REAR FINAL GEAR
1989 TRX300 A FINAL DRIVEN GEAR
1989 TRX350D A FRONT FINAL GEAR
1989 TRX350D A REAR FINAL GEAR
1990 TRX300 A FINAL DRIVEN GEAR
1990 TRX300FW A FINAL DRIVEN GEAR
1990 TRX300FW A FW FRONT FINAL GEAR
1991 TRX300 A FINAL DRIVEN GEAR
1991 TRX300 AN FINAL DRIVEN GEAR
1991 TRX300FW A FINAL DRIVEN GEAR
1991 TRX300FW A FW FRONT FINAL GEAR
1991 TRX300FW AN FINAL DRIVEN GEAR
1991 TRX300FW AN FW FRONT FINAL GEAR
1992 TRX300 A FINAL DRIVEN GEAR
1992 TRX300 AN FINAL DRIVEN GEAR
1992 TRX300FW A FINAL DRIVEN GEAR
1992 TRX300FW A TRX300FWDRIVESHAFT (TRX300FW)
1992 TRX300FW AN FINAL DRIVEN GEAR
1992 TRX300FW AN TRX300FWDRIVESHAFT (TRX300FW)
1993 TRX300 A FINAL DRIVEN GEAR
1993 TRX300FW A FINAL DRIVEN GEAR
1993 TRX300FW A TRX300FWDRIVESHAFT (TRX300FW)
1993 TRX300FW AN FINAL DRIVEN GEAR
1993 TRX300FW AN TRX300FWDRIVESHAFT (TRX300FW)
1994 TRX300 A FINAL DRIVEN GEAR
1994 TRX300 AN FINAL DRIVEN GEAR
1994 TRX300FW A FINAL DRIVEN GEAR
1994 TRX300FW A TRX300FWDRIVESHAFT (TRX300FW)
1994 TRX300FW AN FINAL DRIVEN GEAR
1994 TRX300FW AN TRX300FWDRIVESHAFT (TRX300FW)
1995 TRX300 A FINAL DRIVEN GEAR
1995 TRX300 AN FINAL DRIVEN GEAR
1995 TRX300FW A FINAL DRIVEN GEAR
1995 TRX300FW A TRX300FWDRIVESHAFT (TRX300FW)
1995 TRX300FW AN FINAL DRIVEN GEAR
1995 TRX300FW AN TRX300FWDRIVESHAFT (TRX300FW)
1996 TRX300 A FINAL DRIVEN GEAR
1996 TRX300 AN FINAL DRIVEN GEAR
1996 TRX300FW A 300 FW FRONT FINAL GEAR
1996 TRX300FW A FINAL DRIVEN GEAR
1996 TRX300FW AN 300 FW FRONT FINAL GEAR
1996 TRX300FW AN FINAL DRIVEN GEAR
1997 TRX300 A FINAL DRIVEN GEAR
1997 TRX300 AN FINAL DRIVEN GEAR
1997 TRX300FW A 300 FW FRONT FINAL GEAR
1997 TRX300FW A FINAL DRIVEN GEAR
1997 TRX300FW AN 300 FW FRONT FINAL GEAR
1997 TRX300FW AN FINAL DRIVEN GEAR
1998 TRX300 A FINAL DRIVEN GEAR
1998 TRX300 AC FINAL DRIVEN GEAR
1998 TRX300FW A 300 FW FRONT FINAL GEAR
1998 TRX300FW A FINAL DRIVEN GEAR
1998 TRX300FW AC 300 FW FRONT FINAL GEAR
1998 TRX300FW AC FINAL DRIVEN GEAR
1999 TRX300 A FINAL DRIVEN GEAR
1999 TRX300 AC FINAL DRIVEN GEAR
1999 TRX300FW A 300 FW FRONT FINAL GEAR
1999 TRX300FW A FINAL DRIVEN GEAR
1999 TRX300FW AC 300 FW FRONT FINAL GEAR
1999 TRX300FW AC FINAL DRIVEN GEAR
2000 TRX300 A FINAL DRIVEN GEAR
2000 TRX300 AC FINAL DRIVEN GEAR
2000 TRX300FW A DRIVESHAFT
2000 TRX300FW A FINAL DRIVEN GEAR
2000 TRX300FW AC DRIVESHAFT
2000 TRX300FW AC FINAL DRIVEN GEAR
2000 TRX350FE A FRONT FINAL GEAR
2000 TRX350FM A FRONT FINAL GEAR
2001 TRX350FE 2A FRONT FINAL GEAR
2001 TRX350FE A FRONT FINAL GEAR
2001 TRX350FM 2A FRONT FINAL GEAR
2001 TRX350FM A FRONT FINAL GEAR
2002 TRX350FE 2A FRONT FINAL GEAR
2002 TRX350FE A FRONT FINAL GEAR
2002 TRX350FM 2A FRONT FINAL GEAR
2002 TRX350FM A FRONT FINAL GEAR
2003 TRX350FE 2A FRONT FINAL GEAR
2003 TRX350FE A FRONT FINAL GEAR
2003 TRX350FM 2A FRONT FINAL GEAR
2003 TRX350FM A FRONT FINAL GEAR
2004 TRX350FE 2A FRONT FINAL GEAR
2004 TRX350FE A FRONT FINAL GEAR
2004 TRX350FM 2A FRONT FINAL GEAR
2004 TRX350FM A FRONT FINAL GEAR
2005 TRX350FE A FRONT FINAL GEAR
2005 TRX350FM A FRONT FINAL GEAR
2006 TRX350FE A FRONT FINAL GEAR
2006 TRX350FM A FRONT FINAL GEAR
2012 TRX500FE FRONT FINAL GEAR
2012 TRX500FM FRONT FINAL GEAR
2012 TRX500FPE FRONT FINAL GEAR
2012 TRX500FPM FRONT FINAL GEAR
2013 TRX500FE FRONT FINAL GEAR
2013 TRX500FM FRONT FINAL GEAR
2013 TRX500FPE FRONT FINAL GEAR
2013 TRX500FPM FRONT FINAL GEAR
2014 TRX420FA1 2AC FRONT FINAL GEAR
2014 TRX420FA1 AC FRONT FINAL GEAR
2014 TRX420FA2 2AC FRONT FINAL GEAR
2014 TRX420FA2 AC FRONT FINAL GEAR
2014 TRX420FE1 2AC FRONT FINAL GEAR
2014 TRX420FE1 AC FRONT FINAL GEAR
2014 TRX420FM1 2AC FRONT FINAL GEAR
2014 TRX420FM1 AC FRONT FINAL GEAR
2014 TRX420FM2 2AC FRONT FINAL GEAR
2014 TRX420FM2 AC FRONT FINAL GEAR
2014 TRX500FE1 2AC FRONT FINAL GEAR
2014 TRX500FE1 AC FRONT FINAL GEAR
2014 TRX500FE2 2AC FRONT FINAL GEAR
2014 TRX500FE2 AC FRONT FINAL GEAR
2014 TRX500FM1 2AC FRONT FINAL GEAR
2014 TRX500FM1 AC FRONT FINAL GEAR
2014 TRX500FM2 2AC FRONT FINAL GEAR
2014 TRX500FM2 AC FRONT FINAL GEAR
2015 TRX420FA1 2AC FRONT FINAL GEAR
2015 TRX420FA1 AC FRONT FINAL GEAR
2015 TRX420FA2 2AC FRONT FINAL GEAR
2015 TRX420FA2 AC FRONT FINAL GEAR
2015 TRX420FA5 FRONT FINAL GEAR
2015 TRX420FA6 FRONT FINAL GEAR
2015 TRX420FE1 2AC FRONT FINAL GEAR
2015 TRX420FE1 AC FRONT FINAL GEAR
2015 TRX420FM1 2AC FRONT FINAL GEAR
2015 TRX420FM1 AC FRONT FINAL GEAR
2015 TRX420FM2 2AC FRONT FINAL GEAR
2015 TRX420FM2 AC FRONT FINAL GEAR
2015 TRX500FA5 FRONT FINAL GEAR
2015 TRX500FA6 FRONT FINAL GEAR
2015 TRX500FA7 FRONT FINAL GEAR
2015 TRX500FE1 2AC FRONT FINAL GEAR
2015 TRX500FE1 AC FRONT FINAL GEAR
2015 TRX500FE2 2AC FRONT FINAL GEAR
2015 TRX500FE2 AC FRONT FINAL GEAR
2015 TRX500FM1 2AC FRONT FINAL GEAR
2015 TRX500FM1 AC FRONT FINAL GEAR
2015 TRX500FM2 2AC FRONT FINAL GEAR
2015 TRX500FM2 AC FRONT FINAL GEAR
2015 TRX500FM5 FRONT FINAL GEAR
2015 TRX500FM6 FRONT FINAL GEAR
2015 TRX500FM7 FRONT FINAL GEAR
2016 TRX420FA1 FRONT FINAL GEAR
2016 TRX420FA2 FRONT FINAL GEAR
2016 TRX420FA5 FRONT FINAL GEAR
2016 TRX420FA6 FRONT FINAL GEAR
2016 TRX420FE1 FRONT FINAL GEAR
2016 TRX420FM1 FRONT FINAL GEAR
2016 TRX420FM2 FRONT FINAL GEAR
2016 TRX500FA5 FRONT FINAL GEAR
2016 TRX500FA6 FRONT FINAL GEAR
2016 TRX500FA7 FRONT FINAL GEAR
2016 TRX500FE1 FRONT FINAL GEAR
2016 TRX500FE2 FRONT FINAL GEAR
2016 TRX500FM1 FRONT FINAL GEAR
2016 TRX500FM2 FRONT FINAL GEAR
2016 TRX500FM5 FRONT FINAL GEAR
2016 TRX500FM6 FRONT FINAL GEAR
2016 TRX500FM7 FRONT FINAL GEAR
1983 CB550SC A SIDE GEAR CASE
1983 CB650SC A SIDE GEAR CASE
1984 CB650SC A SIDE GEAR CASE
1984 CB650SC AC SIDE GEAR CASE
1985 CB650SC A SIDE GEAR CASE
1985 CB650SC AC SIDE GEAR CASE
Discussion Starter #9
Ok well if you don't want to spend more than 6$ and wait for shipping use my method. Home Depot pipe fitting and a grinder.
1 - 9 of 9 Posts
