'09 foreman es,.,.,.on the right side i see idle screw,primer, both with knob you can turn by hand. to drain carb. is it the yellow flat tipped screw on right of carb. or is there a screw on bottom of bowl???i possibly have water in carb. if it's the yellow flat tip, i loosened it almost all the way out and nothing drained even with gas on??
The drain is on the bottom of the bowl.
It's the screw that you see at the bottom of the bowl in the picture below.
