1 - 9 of 9 Posts
Hi guys I'm new here so any help will be great . So my issue is I replaced the bearing in my steering shaft on my 1989 Honda 300 but when I pulled up on the steering shaft to get it out of the hole I must of pulled the wires out or something cause now my neutral light won't come on at all none of lights work at all any idea of what I did thanks.
There is a black plastic junction box on the front of the steering shaft , I would guess you pulled on a wire and disconnected a plug inside the box , one 10mm headed bolt will open the box , you can do it with the fender on but it is not going to be easy
you see the box Goober circled , the ignition switch and other wires connect inside that box , one screw holds the box to the frame , the other bolt keeps the box shut , pick the right bolt ------ the wiring inside the box is like 10 lbs of stuff in a 5 lb bag , well not that bad LOL
Thank you fishfiles I didn't have a bunch of wires disconnected it all working again oh btw ik it's another account I don't now how but I messed up my password on my last one and couldn't change the password so I made a new account but thank you so much
Just tossing in a shorty---What was your old handle/name ?
i forgot my password once.:smile goose fixed it, or was it admin? :grin
use the, contact us, at the bottom of page. might just work as well
1 - 9 of 9 Posts
