How easily should my honda rancher 4x4 roll when in neutral?
Seems like it's gotten kinda hard to push around. I don't hear anything odd. Good gear oil levels. The brakes all work ok so i don't think they are stuck or rubbing, but it just seems like something is causing some resistance. and it seems to get really hot after a ride but the light doesn't come on. When I jack it up it is a little hard to spin the wheels. It's harder to push out of the garage than it was when I bought it a few years ago. Used to roll right out.
What else should be checked out?
Thanks
350 ES 4X4
Well you are getting older lols
Pull drums and clean; lube the brake cables and foot lever as I’ve seen brake be adjusted properly but the pedal/levers don’t fully return
adjust clutch
maybe you have a wheel bearing or drive axle going bad. check manual for troubleshooting.
chances are, your brakes on the front or rear are sticking.
