you cant go by just look. measure your piston to bore clearance, is the bore out of round? how do the rings look? cant tell by the pictures how the oil rings are doing.
how does the other side of the piston look? any dark coloring, if so that top end has been overheated, almost guaranteeing your cylinder is out of round.
get that cylinder and piston off, take it to a competent machinist. you'll be glad you did in the long run.
BTW, I would strongly recommend valve stem seals at bare minimum while your in there.
