1 - 13 of 13 Posts
Shifting issues 2013 4x4 420 ES 933 km
Won't shift up or down from neutral or any gear selected manually I get four flashes on my dashboard for neutral or any any gear
Help! Thanks
Welcome to the forums.
Have you checked the factory service manual for fault diagnosis yet? Any issues before you lost the use of shifting? Been in deep water/mud?
Discussion Starter #3
Only issue was overdue oil change no mud or water always in garage used very little
Changed oil according to owners manual and reset display
Tried different 30a shift motor fuse and it worked for a few shifts then quit again back to the few quick blinks then four definite blinks for whatever gear it's in!
time to remove the shifting motor cover at front of engine, and inspect the gears under it. DO NOT PULL THE SHIFT MOTOR APART !!!.
Will the gears shift manually using the shift tool?? If yes, then you need to check the gearshift switch wiring. If no, it may be a problem with the linkage. The manual will take you step-by-step how and what to check.
Can't seem to pick up the service manual for my machine
2013 TRX420FPE with Power Steering FOURTRAX RANCHER
Can someone download it and forward it to [email removed]
Much appreciated
is this the original battery, as low voltage/weaker battery will cause shifting issue's
es need a GOOD battery to work well
Hi: Count the quick blinks and the slow blinks -- that is the error code to find the problem
Discussion Starter #10
Thanks everyone for now
Just busy in the hay field, got a drought going on here in central Manitoba, Canada and trying to find some feed
Battery is original and tests at 12.56V
Manual shift lever works fine
Discussion Starter #11
RE: MelaTV
Thanks
2 slow blinks followed by 4 quick blinks for any gear including neutral
Cannot download a service manual for my machine on the forum link so cannot isolate error code ???
RE: MelaTV
Thanks
Here is the direct link. There is not a 2013 manual but the 2014 will work for you.
https://drive.google.com/drive/folders/12hzs10L_Gwu0aVyp8vhmEXNdf2N2P7tk
If you have a PDF program you should be able to download and open the file. If not, first install a PDF program, then download the manual.
Hi: That is code 24
Look In section 14 -- page 14-29 of the service manual
1 - 13 of 13 Posts
