1 - 12 of 12 Posts
Have you checked the front driveshaft to be sure it's fully seating in the transfer case and in the front diff?
I'm still thinking CV, but it would most likely also be noisy/clicky when turning.
I'm not the most experienced guy here by any means, and I'm sure the "usual suspects" will be along shortly to give their opinions/advice as well.
they do have a clutch pack in the front differential in case you never tore one all apart ?..lol.
When I was doing my build on the Mean Green Machine, I had a clicking in the front end when turning the wheels. Whether it was being driven or with the front end jacked up. Turn the handlebars...clicky clicky.
Sounded like it was coming from the front diff. Even used a backyard stethoscope (long screwdriver) to "listen" to the diff. I had already planned to replace all the bearings and seals in the diff anyway, so much to my surprise it still clicked/popped after it was all put back together.
Sure enough, it was the front right CV. Replaced them both for $120 and problem was solved.
Chances are pretty high that it's the problem you have as well. Unless the front diff had been completely swamped and been driven with sand/dirt in it for a while, it is probably ok. The CVs are definitely the weakest link (by design) in the front drivetrain.
Discussion Starter · #11 ·
Surprising this Atv is a 95 and has never been submerged. And when I bought it 4 months ago I changed all fluids and there was no signs of anything bad in the diff. Just black oil needing to be changed but it wasn't bad.
just because there were no signs of it being sunk ?, does not mean its not time to inspect/replace worn/damaged parts ?. it's old, old age makes things not work so good ?, ( i'm old..so I know..lol ), really though, don't think for one min, all parts are in great shape, just because it was never sunk ? :).
1 - 12 of 12 Posts
