Only use NGK on a Honda.when is the last time it ran? i have had bad luck with champion plugs. i got one at wallyworld. you would think once is enough. i did it 2 times.. 1 at wally, one at autozone. they did however work for a bit, then zonked out.
how brave are you? you could stick a screw driver into the boot, hold the screwdriver metal, put your other hand on the frame, have someone turn it over. :smile
i wont do it. bok, bok,, bok, bok. bok..
