1 - 2 of 2 Posts
Just take the side covers off and drill a small hole in each side of the seal. Put a screw in each hole and use a pair of pliers to pull the seals out. You may have to place something under the pliers, so you will will have some leverage to pry them out.
Of course, you will have to remove the flywheel and clutch and primary drive gear, first.
1 - 2 of 2 Posts
