ok guys this has been goin on for a while now prob two years. my breather from the crankcase blows out smoke once my 97 300 4x4 gets harmed up, I have no idea why can someone help?
thanks,:sad:
thanks,:sad:
is the oil level too full ?..the breather tube is suppose to let the crank case breath..this is from unburned gas from the cylinder..if they don't have alittle blow by..or blow out so to speak..they can really mess up the cylinder and lower end..check your oil level..sounds like there is too much oil in it..you may even have water inside your lower engine.ok guys this has been goin on for a while now prob two years. my breather from the crankcase blows out smoke once my 97 300 4x4 gets harmed up, I have no idea why can someone help?
thanks,:sad:
