I fell into a deep hole and flipped my atv by accident. Anyways my display is now saying oil change. My oil level is good and I just changed the oil before the ride and added a new oil filter. Bike shifts fine and runs well.
Also there are 4 little black connectors to the left of the throttle that were unhooked I hooked them back in but what are these for? I plugged them in the best I could. Thanks for any advice.
You can reset your oil change indicator [check the manual]. What machine do you have? The plugs are probably for the stop light switch or other similar switches, but hard to guess without knowing the machine.
It is a 2006 trx400fa. The 4 black plugs are to the left of the throttle. Like 4 little square rubber connectors that plug into 4 prongs. I did not get a manual with this bike unfortunately.
