So for as long as I've owned my Honda 300 it's given me problems starting. All my mods are in my sig, so you can see what I have...
IF it's left outside overnite and temps are around freezing or very chilly the quad will barely turn over. I need to kick it. Fires up 1st kick.
IF it's left for days or weeks without starting in a heated garage, it's a crap shoot if it will fire up or if I need to kick it.. bur way better than if it was left out overnite. Always first kick it's running.
IF I have to kick it because the battery won't fire it up, & I run the quad for a little bit or hours, it will always fire right up with the battery.
I had installed a new battery over a year ago thinking it was the culprit, however it continued to do the same thing.
I do have the winch wired up to the aux pink wires direct. it's not with key power.
I'm leaning towards the rectifier?? I remember a while back I tried to check the voltage while cranking & was getting something like 7v, but while running it was 13v or 14v if memory serves me correct...
I would love some advice so I can check some things before I just start throwing $$ at it replacing parts!!!!!
Thanks in advance!
Thanks in advance!
