1 - 12 of 12 Posts
Hi, New to the forums. Long time ATV and Honda rider. But just bought a 2017 Rancher with a DCT and EPS.
My question was about the correct way to shift while riding in ES mode. If I recall on the older Ranchers without the AUTO DCT, Honda recommended that you release the throttle before each shift. Shouldn't I be able to shift without releasing the throttle because that's exactly how it works in auto mode?
Thanks
I think that shifting during acceleration as you described is one of the advantages of the DCT. Prior to the shift, the mechanical drive parts are already engaged for the next higher or lower gear, and all that happens is that one clutch quickly disengages while the other engages. Since you don't have to synchronize gear speeds in order to make a smooth shift, there is no need to fiddle with the throttle during a shift.
Isn't there some information about shifting technique in your owner's manual?
I did glance at the manual and it states to release the throttle before a shift while in ESP mode. It seems silly to me, which is why I asked the question in the first place
Mechanically, the DCT can be shifted any way and no harm will come of it. The clutches are set up in a way to always slip enough during the shifts to allow the proper gear mesh to occur. And in Auto mode it is very subtle, but you are holding the throttle steady and the electronics are controlling the engine and "chopping" or "blipping" the the throttle for you.
In ES mode, the manual only tells you to let off the throttle to make it a smoother transition for you. But all you need is a quick chop or blip of the throttle. That's how it should be done on a regular ES (no DCT) or footshift also.
Reactions: retro and Melatv
I think its never good for long life to be on the throttle when engaging gears, you need a slight pause in things to get them seated good then hammer away!
why risk it? its a hair of a second that is all that is needed,
It's true that it's not good for long life to be on the throttle when engaging gears, but the DCT doesn't work that way. You should study up on it. The driving gears for the next higher or lower ratio are already engaged before the shift takes place. That's why you don't hear any clanking, banging, or grinding coming from the DCT during a shift. Shift at will. No harm will come to the tranny.
and the OP posted the manual stated this, so???
so if the manual and HONDA is stating to let off the throttle, even with the DCT, I think they know best as to what will make things last? harm or??
but what do I know ?? maybe not as much as HONDA!
but seems we agree to let off the throttle when shifting even again on DCT machine? if the OP posted out of his DCT manual as he says he did?
LOL
LOL
Mrbb, there is lots of good information on the internet that explains how a DCT works. Studying it will be time well spent. I think you will find it enlightening.
I've gotten pissed off at my "new rubi" when i had it, for the delay in shifts that i would hold it to the floor so to say & shift it up & up & up... the engine would do its own 'blipping' of the throttle for me. Could hear it cut out for a brief second.
Anyway, i got tired of the delay & got rid of it after about 2000 miles. Thats not saying what to do, thats saying what i did.
LOL
thanks for the thought, but I have no desire to STUDY any info on the DCT, I still stand by my POINT< that NOT shifting while under throttle will add longer life to things, and I DO get what your saying and the design, of gears being sort of in mesh already!
the point of my view is again, AT first hook up of gears,(even gears at mesh some what) stronger bursts of RPM's and HP is never a good idea on a machine you want to live a long time, , NOW if your racing and making money off your toys, Have at it, and hammer down LOL
and back to again IF Honda states in manual to let off throttle at shifts, I would suggest following there advice , NOT mine, if you want your atv to last as long as possible, seems like good advice to me!
I have zero plans to BUY a DCT ATV, so, this is MY just opinion and well, echoing what the OP posted HONDA said in there owners manual!
The 'correct way' to shift is the way Honda and its engineers have stated in the owners manual . . . why would anyone 'study' the internet for a different answer ?
This is similar to the folks that know better than the Honda designers and engineers, and use hi-octane fuel instead of the octane the motor was designed to use. . . . . :smile
1 - 12 of 12 Posts
