This may sound like a stupid question, as I'm prone to ask sometimes. But...I drive a '96 Cherokee with the inline 4.0 non-interference engine and it doesn't like driving in the heat so much. Since I'm a car down right now I'm driving it a LOT more than I used to. After a lot of driving in this hot weather it starts slower, but still starts and runs ok.
So to help it out I've been raising the hood and putting 2 box fans right on top of the engine to help it cool. I hadn't thought about it but my Mom asked if cooling it down too quickly could be bad for the engine. And since I don't know I thought I'd ask here.
Any harm in using my method to cool an engine down much more quickly than normal?
Nah one if them old iron block 4.0s you could submerge that engine in ice water after driving it on a 200 degree day and never have a concern. Now cast aluminum motors would be a different story. I had a 2000 dakota mud truck that the guy before me thought was a submarine and the heads were cracked between all the valves. Guy was getting it crazy hot and running it through creeks and rivers though so thats kinda to be expected.
Heat naturally rises, I'd be inclined to mount the fans under the bonnet/hood with some kind of vent in the bonnet/hood and suck the air out rather than force the hot air down through the chassis.
Alternatively, save your money, fit spacers between the bonnet/hood hinges to create a gap between the wings and hood.
Reactions: LedFTed
dont throw cold water on a hot engine.. could crack a block.. your thermostat, could be bad, radiator could be clogged somewhat.. when you take out the cap do you see white in the tube's?, mineral buildup.. i had a 2 core radiator once an switched it for a 3 core.. i also switched out a 5 blade fan for a 7 blade fan. the 7 had a better pitch also..
the 55 chevy truck, i could never get the engine temp up, past 140F. good in the summer, but cold in the winter. real cold.. so in the winter, i would light a coleman lantern, set it on the passenger floor board tilted over in the corner, so the windows would not get frosted, inside and out. 6 banger 230 cu.in..
life in the fast lane. :)
I have read break-in procedures on engine rebuilds call for putting a shop fan on the engine during the start up and run cycles ---- on a similar note , I have heard people theorize that running a hot engine into the water will shorten the life of the engine ----- it is what it is .....
Discussion Starter #6
Thanks for all the good advice. That's what I thought...it's all good. I don't really think it's running unusually warm. I've been told these engines run hot naturally, I guess. It's done this before when I've run it a lot, it's just that I rarely run it this much so I'm seeing it more now.
I've been told these engines run hot naturally[
You've been told correct ^^(RUN a oem thermostat with a jiggle valve!!! )
