you should be ok, if I remember right ?, the trx250 recon's call for around that. i'm sure new, they may be a tad higher ?, but it should run.Ok with the throttle wide open its around 97-100psi
took me a min to see it..lol. ok, then yes, his is too low. but how you going to get 800 rpms pull starting it ?..lol.![]()
185 psi
185 psi
Chuck Norris could...took me a min to see it..lol. ok, then yes, his is too low. but how you going to get 800 rpms pull starting it ?..lol.![]()
185 psi
then you better hire him to go pull start it ?, cuz ain't no one I know of..is gonna make that motor spin 800 rpms just from pull starting it !..lmao.Chuck Norris could...took me a min to see it..lol. ok, then yes, his is too low. but how you going to get 800 rpms pull starting it ?..lol.![]()
185 psi
lmao..no kidding..me either !!..lmfaooo.took me a min to see it..lol. ok, then yes, his is too low. but how you going to get 800 rpms pull starting it ?..lol.![]()
185 psi
By being a better, more able bodied man than me... lol
with the electric starter ?, yeah, but pull starting it ?, don't think so..lol.Crank it over With the starter is how you'll get 800 rpms... Lol
Sent from my LG-US996 using Tapatalk
:lifting:took me a min to see it..lol. ok, then yes, his is too low. but how you going to get 800 rpms pull starting it ?..lol.![]()
185 psi
I agree...some what ?, most owners don't hold the throttle wide open when cranking their atv over ?, sooo, to do a compression test the correct way, you should hold the throttle wide open when doing so, but most people don't do the throttle when starting their atv. and I also agree, I don't know how many rpms a electric starter cranks them over ?. funny Honda would print this info, but show no way of backing this info up ?, maybe with a tach hooked up ?.:lifting:took me a min to see it..lol. ok, then yes, his is too low. but how you going to get 800 rpms pull starting it ?..lol.![]()
185 psi
Not sure really, I was thinking the starter motor might turn it at half that. Either way it's only going to build so much pressure no matter how fast you spin it.
starters are cheap on ebay, I get mine from a company on ebay in TN. make sure you get a battery too !, DO NOT RUN IT WITHOUT A BATTERY !!.Yeah I don't have starter for the recon yet.
