So I read how folks have pulled off the clutch to get to the oil pump and cam chain, using a 2 or 3 jaw puller and hose clamps. My trx200 doesn't seem to have enough clearance to get hose clamps in there, and the back of the centrifugal clutch is rounded, so I wouldn't be able to get a grip with the flat part of the puller. I did try to tap around the edge with a plastic mallet last night, but it wouldn't budge.
The next question is, oil filter and should I replace the clutch pads and discs?
I don't see an oil filter yet, just the screen. Does this model not come with one? (1994 trxd200 type 2)
I haven't noticed any performance or shifting issues, so do I need to replace the clutch parts?
One way bearing. Does this always get replaced or is it replaced only when symptoms come up?
