1 - 20 of 20 Posts
i have a 2000 rancher 350 4x4 and im in process of putting a new top end in and while I have the motor out id like to do a clutch kit in it and possible gear reduction. what clutch kit should I get and where can I get a gear reduction?
Discussion Starter #3
What tires are you wanting to run? Get the EPI clutch kit with highest stall. I think its extreme?
Sent from my Z992 using Tapatalk
right now I have 26" vampires. 26x8 front 26x12 rear and I think the rear tires are just draining the power all around. im looking into some 27x9.5 outlaws for next spring but I just want better low end torque
Banned
I have 28" 12.5 and 9.5" wide Outlaws on my 2005 350 Rancher and she spins them no trouble except when tire deep thick mud.
Banned
I will suggest clutch it first with the EPI kit. And check your valve clearances, air filter, spark plug, etc to make sure you have a strong running engine.
Discussion Starter #6
do you know what the valve clearance should be?
Banned
No I do not know. Check in manual section on here and there should be one for download. I need to do my Ranchers valves soon.
Look up extreme rancher on highlifter r gotmuddy they well get u a gr I would go with the 23.5 % and clutch kit to cause the gr is on the clutch bssket I think but with that gr alone u can spin 29.5 outlaws from what Ive read and heard
Discussion Starter #9
I had a highlifter account but forgot my password and it wont let me make another account so do you possibly know any other way of contacting them?
i had the same question about gear reduction, and i emailed high lifter and they told me that they dont make a gear reduction for the 350, and the other applications they have for the ranchers wont work.i have a 05 350 with 27 inch mud lites and was thinking of doing the same because of the tire height.
Here is extreme ranchers number his name is james clark
337-280-5535
If you do a reduction do not waste your time on a clutch kit. We tried it on a 300 with clutch kit and reduction and it made it hard to ride.
I got a gr and clutch kit in mine it just take some getting use to but I love my setup so far
jwhite , I have a 450FM , it has a 300 clutch basket in it , the reduction is like 18% , it was plug and play , no welding , that 400 should be real close to the same thing ---- go to a parts site and see it the clutch and primary are the same in a 400 and 450
this is the list of models which use the same clutch basket in my 450 and it looks like you just missed it with that 2005 , 2003 was the last 400 on this list
This Honda 22100-HN0-670 CLUTCH (OUTER) fits the following models and components:
Honda ATV 1995 TRX400FW A - FOURTRAX FORMAN Clutch
Honda ATV 1995 TRX400FW AN - FOURTRAX FORMAN Clutch
Honda ATV 1996 TRX400FW A - FOURTRAX FORMAN Clutch
Honda ATV 1996 TRX400FW AN - FOURTRAX FORMAN Clutch
Honda ATV 1997 TRX400FW A - FOURTRAX FORMAN Clutch
Honda ATV 1997 TRX400FW AN - FOURTRAX FORMAN Clutch
Honda ATV 1998 TRX400FW AC - FOURTRAX FORMAN Clutch
Honda ATV 1998 TRX450S AM - FOURTRAX FORMAN S Clutch
Honda ATV 1998 TRX400FW A - FOURTRAX FORMAN Clutch
Honda ATV 1998 TRX450ES AM - FOURTRAX FORMAN ES Clutch
Honda ATV 1998 TRX450ES A - FOURTRAX FORMAN ES Clutch
Honda ATV 1998 TRX450S A - FOURTRAX FORMAN S Clutch
Honda ATV 1999 TRX400FW A - FOURTRAX FORMAN Clutch
Honda ATV 1999 TRX450ES A - FOURTRAX FORMAN ES Clutch
Honda ATV 1999 TRX450S A - FOURTRAX FORMAN S Clutch
Honda ATV 2000 TRX400FW A - FOURTRAX FORMAN Clutch
Honda ATV 2000 TRX450S A - FOURTRAX FORMAN ES Clutch
Honda ATV 2000 TRX450ES A - FOURTRAX FORMAN ES Clutch
Honda ATV 2001 TRX450S A - FOURTRAX FOREMAN S Clutch
Honda ATV 2001 TRX400FW A - FOURTRAX FOREMAN Clutch
Honda ATV 2001 TRX450ES A - FOURTRAX FOREMAN ES Clutch
Honda ATV 2002 TRX450FE A - FOURTRAX FOREMAN ES Clutch
Honda ATV 2002 TRX450FM A - FOURTRAX FOREMAN S Clutch
Honda ATV 2002 TRX400FW A - FOURTRAX FOREMAN Clutch
Honda ATV 2003 TRX400FW A - FOURTRAX FOREMAN Clutch
Honda ATV 2003 TRX450FM A - FOURTRAX FOREMAN S Clutch
Honda ATV 2003 TRX450FE A - FOURTRAX FOREMAN ES Clutch
Honda ATV 2004 TRX450FE A - FOURTRAX FOREMAN ES Clutch
Honda ATV 2004 TRX450FM A - FOURTRAX FOREMAN S Clutch
05 Rancher 400 is a completely different machine than the 450 Foreman, you are probably thinking of the 400 Foreman fish, which would have to be a 95-03 model. That 300 basket and primary gear is good for 14% GR, if you wanted 18% you'd need the gears from a ATC250ES (1985). I haven't completely figured it out yet, but I know if you put the basket gear onto the 450's basket you can use that and get the 18%, you can't use the 250 basket because it doesn't hold as many disks. However the difference between the two gear sets is in the primary gear, one less tooth IIRC on the 250, so you might be able to just use the 300 basket as a unit, then the 85 250 primary gear. I don't know if they will mesh correctly though so I need to figure that out.
But we are getting off topic. I guess that's more interesting than the actual answer to the question. There is NO gear reduction available for the 400AT, what you have is as good as it gets.
Mac , All that info needs to be stored away some where , in my younger days I had a photostatic memory , nowdays I have trouble remembering my zip code
I never knew there were two 400's , and never realized they made them for so long
If you need a gr, I got mine from Jeremy Lee. You can find him on facebook and contact him from there. Just my 2 cents. Overall, I am very happy with my 35% gr.
Haha it is stored somewhere man, all in my head. But your right, this stuff really should be put down somewhere, probably on paper because you never know, forums disappear too.
1 - 20 of 20 Posts
