I'm getting oil pressure to the 2nd clutch up to 110 psi but I'm not getting a reading at all for the first clutch? Any ideas or things to look for to solve issue would be appreciated. 2015 rancher Dct
Oil that is violently being mixed with air foams up & whips up into a "whipped cream" looking substance. Once air becomes mixed with oil in a closed system it is no longer a liquid and becomes compressible, which makes it heat up and those foaming/whipping conditions worsen. Oil is no longer a lubricant, nor a hydraulic fluid once air begins to mix with it.
By the time you can begin to drain clean oil for inspection (or pull the dipstick after waiting for oil to return to the sump after shutdown) it will have already returned to a liquid state (motor oil has an anti-foaming additive that speeds up the separation process) so this condition (whipped creamy oil) can only be detected while the motor is running. Sometimes only by cracking open a pressure test tap plug (or using a gauge on it) can it be detected, as is common on automatic transmissions on cars and trucks.After the whipped air/oil sits still for a while most of the air escapes and an air/oil mixture returns to liquid form... except where trapped in an enclosed space. Damage always occurs as a result if not detected immediately and remedied.
