Hey everyone, I’ve got a 99 TRX300fw that I inherited from my dad. It had been sitting for several years so I got her running with a new spark plug, CDI, oil change/filter, air filter, new gas, and deep carb clean with a rebuild kit. It fires up right away on full choke and sounds like it’s pretty healthy but it won’t idle without it. I’ve read what seems like hundreds of the forums on here saying to clean the carb again and make sure the pilot jet and air/fuel mixture screw are clear and I can assure you they are. Ive cleaned it several times now and blown compressed air through all the jets and passage ways in the carb as well. I’ve also adjusted the valve clearance and that didn’t help either.
I think it’s also important to note that it smokes on startup as well as when you rev it up. I’m planning on putting in new valve seals and rings but I didn’t think that would affect the idle.
Any help is much appreciated thanks in advance.
