Hi: Just some info I have,
ENGINE/DRIVETRAIN
Powerful 420cc longitudinally mounted engine eliminates 90-degree power transfers and boasts exceptional horsepower and torque. Overhead valve design provides compact engine dimensions for excellent ground clearance.
Cylinder head redesigned with higher compression, revised camshaft profile and larger intake valves (38 vs. 35mm) and exhaust valves (33 vs. 30mm) to ensure strong mid-range and top-end power
Programmed Fuel-Injection (PGM-FI) features a 34mm throttle body, 12-hole Denso injector, and Idle Air Control Valve (IACV) for crisp performance, excellent economy and trouble-free operation in cold conditions and varying altitudes
Large 7.2-liter airbox with washable, reusable foam air filter provides more air to the engine for increased performance
New high-capacity oil system features a high-flow filter and a two-rotor pump to provide oil for the engine and the pressurized transmission clutches
Rubber-cushion engine mounting and gear-driven counterbalancer reduce vibration
Large radiator with cooling fan ensures optimal engine cooling under difficult operating conditions
