i got a 98 300 trx 4x4, she stopped charging here a month ago, so i tested the stator i through as per honda spec, it come up with no resistance and no ac output, so i changed the stator, now i got reading but nowhere near what they should be i thought, with it running, testing the voltage output at rectifier it starts at 9 goes to 13.9 at quarter throttle then drops off to 3 volts from there to wot. so i changed the rectifier/ regulator and got the same result.?????? i'm guessing the the r/r is good seeing how 2 of them have the same reading , stator not so sure now , anyone have number to test the stator, or any ideas????
