This might be a stupid question, but since this is the first one I've owned I'll ask anyway. How often should you change the oil, and what brand(s) do you suggest? Oh, mine is a '97 300ex. Thanks. Marc
thank you..The maintenance schedule for the 300EX says to change the oil and filter every 600 miles or every 100 hours. The recommended oil is Honda GN4 10W-40.
Yamalube is designed for wet clutches, so it should work just as good as Honda GN4. If the truth was known, it's probably the same oil anyway.The guy I bought from said he always used yamalube. Is that good oil, or would you stick with the Honda stuff?
