Hi again, how do you adjust the timing chain tensioner on a 1991 trx 350 ( same as (89 trx 350 foreman) the manual does not describe it well. Thanks Eric
It automatically tensions the chain. It's not adjustable. Before you bolt it in, you have to take the bolt out of the end of it. Then take a screwdriver and put in the end of it and wind it in. You have to hold it in with the screwdriver until you bolt it up. Now, just turn the screwdriver loose and it will automatically extend and tension the timing chain.Hi again, how do you adjust the timing chain tensioner on a 1991 trx 350 ( same as (89 trx 350 foreman) the manual does not describe it well. Thanks Eric
Yeah, I remember the '91 TRX350.helmut..i think we ran across this '91 trx350 the other day..and they never sold any of these in the states..not that i know of..lol..anyway..if your timming chain is to far stretched..messing with the chain adjuster wont solve your problem..not if your hearing a ticking from it anyway...if your chain is to far gone..so to speak..you can fix it the right way...buy a new one..orrrrr..you can give it a temp fix...the ******* way..lol..pull the tensioner out..tap a 10 mm socket onto the end of the plunger..or..you can take a piece of flat tin..or metal..cut it wide enough to go in the hole...bend it back around the plunger..crimp it real good..then..use the screwdriver to pull the plunger back..install it in the cylinder..start your bolts..try to get them as tight as posb..then take the screw driver out..finish tightening the bolts..crank it up..see how it does.
i looked it up from the honda dealer websight..on fich..and they stoped making the trx350 in 89..not until 2000 did they come back out with the new 350's.Yeah, I remember the '91 TRX350.helmut..i think we ran across this '91 trx350 the other day..and they never sold any of these in the states..not that i know of..lol..anyway..if your timming chain is to far stretched..messing with the chain adjuster wont solve your problem..not if your hearing a ticking from it anyway...if your chain is to far gone..so to speak..you can fix it the right way...buy a new one..orrrrr..you can give it a temp fix...the ******* way..lol..pull the tensioner out..tap a 10 mm socket onto the end of the plunger..or..you can take a piece of flat tin..or metal..cut it wide enough to go in the hole...bend it back around the plunger..crimp it real good..then..use the screwdriver to pull the plunger back..install it in the cylinder..start your bolts..try to get them as tight as posb..then take the screw driver out..finish tightening the bolts..crank it up..see how it does.
Yeah, I already knew that, but I looked it up to make sure, too, when we were trying to figure out the '91.i looked it up from the honda dealer websight..on fich..and they stoped making the trx350 in 89..not until 2000 did they come back out with the new 350's.Yeah, I remember the '91 TRX350.helmut..i think we ran across this '91 trx350 the other day..and they never sold any of these in the states..not that i know of..lol..anyway..if your timming chain is to far stretched..messing with the chain adjuster wont solve your problem..not if your hearing a ticking from it anyway...if your chain is to far gone..so to speak..you can fix it the right way...buy a new one..orrrrr..you can give it a temp fix...the ******* way..lol..pull the tensioner out..tap a 10 mm socket onto the end of the plunger..or..you can take a piece of flat tin..or metal..cut it wide enough to go in the hole...bend it back around the plunger..crimp it real good..then..use the screwdriver to pull the plunger back..install it in the cylinder..start your bolts..try to get them as tight as posb..then take the screw driver out..finish tightening the bolts..crank it up..see how it does.
what ..no pics with your answer ??..lmfao..your sliping !..lmfaooooo.Yeah, I already knew that, but I looked it up to make sure, too, when we were trying to figure out the '91.i looked it up from the honda dealer websight..on fich..and they stoped making the trx350 in 89..not until 2000 did they come back out with the new 350's.Yeah, I remember the '91 TRX350.
If I would have had to type a lot to answer, then I would have posted pictures. LOL.what ..no pics with your answer ??..lmfao..your sliping !..lmfaooooo.Yeah, I already knew that, but I looked it up to make sure, too, when we were trying to figure out the '91.i looked it up from the honda dealer websight..on fich..and they stoped making the trx350 in 89..not until 2000 did they come back out with the new 350's.
i want my dang pic's dangit !..rotflmao !If I would have had to type a lot to answer, then I would have posted pictures. LOL.what ..no pics with your answer ??..lmfao..your sliping !..lmfaooooo.Yeah, I already knew that, but I looked it up to make sure, too, when we were trying to figure out the '91.
Not this time. You'll have to wait. LOL.i want my dang pic's dangit !..rotflmao !If I would have had to type a lot to answer, then I would have posted pictures. LOL.what ..no pics with your answer ??..lmfao..your sliping !..lmfaooooo.
welllllll crappppp !..lolNot this time. You'll have to wait. LOL.i want my dang pic's dangit !..rotflmao !If I would have had to type a lot to answer, then I would have posted pictures. LOL.
Well, here you go, if you don't want to wait. LOL.welllllll crappppp !..lolNot this time. You'll have to wait. LOL.i want my dang pic's dangit !..rotflmao !
you arse !!!..lmfaoooooo..too funnyyyyy !Well, here you go, if you don't want to wait. LOL.welllllll crappppp !..lolNot this time. You'll have to wait. LOL.
Uploaded with ImageShack.us
