I have a 2001 trx300ex the chain ajustment on the back i know u use an alan wrench to loosen then simply turn the aluminum part to tighten or loosen but the aluminum part is cracked in 2 places is this bad. is anything getting inside of my axle? and ruining bearing need help??
Take some pictures so We can see what you are talking about.
Welcome to the forums
I know what your talking about. It shouldn't be cracked. it depends how deep and where the crack is.
Generally speaking... anything that you travel at speeds through the trails or take jumps on has one crack... REPLACE IT! Two cracks... You're pushing your luck!
