i recently installed a cfm performance airbox. looks amazing on the bike, but am having a couple issues.
issue #1: where would be the best place to run my ground (negative) from my battery. im very leary to run a ground to the airbox itself because i know that aluminum isnt a very good conductor. i also would like to not have to make a new ground strap to run it all the way out of airbox to a ground strap.
issue #2: because the new air box is an inch or two longer than plastic factory piece, the air tube that goes from the air box to the carbuertor isnt bolting up right. i cut the small vent tube like you are supposed to so that it fits in the round hole of the new air box, but it is getting kinked severely when i try bending it onto the carb. does anyone know of any fixes or aftermarket parts?
thank you very much
thank you very much
