2011 Crown Vic here with 305k miles, and today my engine light comes on. Scan at the local Advanced comes up with 4 codes on the cat converter. Guy says I need to get something called Cataclean and run it through the gas tank to correct the problem.
Is it worth doing this...will it make the engine run better or get better gas mileage?
Should I use Cataclean or some other product to get this done?
odds are NOTHING Ina can is going to fix your issue, sounds to me like you got a lot of use out of this vehicle, maybe try funding a used catalytic converter in better condition than your's(*lower miles) at a salvage yard
Those codes are set by o2 sensors. Its possible they could be at fault. All its saying is the reading from up stream before cat converter to down stream past the cat is different. Many things can cause this. Alot of people will cut into the cat itself and remove the guts if you dont have to pass emissions where you are thats the easy fix. More than likely the cat its self is clogged or restricted and thats causing your codes to be thrown. 305k is alot of miles and i would expect you to be on your 4th or 5th set of spark plugs and atleast 2nd maybe 3rd set of o2 sensors. Among many other things.
i would expect you to be on your 4th or 5th set of spark plugs and at least 2nd maybe 3rd set of o2 sensors. Among many other things.
you have a talent for under estimating. Slammed; ya must be an optimist . :grin
catacutter converter.. yep
Yeah I'm not opposed to taking the cat out altogether but I've read it'll make the exhaust louder and I rather not see that happen for now.
The check engine light went off but it came back on yesterday so I got the codes read again. Guy's machine read 4 codes but said they were all the same code...P0430.
I'm game for the lacquer thinner option I've been hearing about. I see low voc lacquer thinner for sale. Wonder if it matters which version you use?
