1 - 12 of 12 Posts
found a 27mm carb that says it fits 01-up trx250ex.stock is 22mm would the 27mm if it works be too big even after adding the exhaust?
I doubt it will be too big all you would have to do is rejet it.
Agree^^^^^^^^^^^!!
Agree, you could make a 4 barrel carb out of a hemi work if you can get it jetted correctly.
alright cool.waiting for email to make sure it has fuel accelerator pump.do you think it'll fit in without modifying the plumbing?
It should.Just stretch the rubber to make it fit.LMAO!!!
thats what i was hoping i could do.i plan on adding a cam and that powroll kit it the near future.would this be big enough because they have a 30mm also.
Should be fine.It's alot over stock already.With being larger bore you have more air flow meaning more fuel and more power.
Discussion Starter · #10 ·
thanks guys ill get the 27mm hopefully i can get it jetted right.
Just take your time.And don't force it on.
1 - 12 of 12 Posts
