I just bought a 1996 300 fourtrax 4x4. Had some head noise, so I started looking into the head and the chain tensioner was broken. So I got a new one, the chain guide (exhaust side), new rocker arms and everything that goes with that. I also bought a cam sprocket and chain. I am having issues with getting the centrifugal clutch off. Any suggestions???? And do I need to take anything else off other than the oil pump to get the old chain off and new on????
The centrifugal clutch has to come off and the oil pump has to come off and I believe the other clutch has to come off, too, if I remember right. Also, the valve cover and tensioner, but you already know that.
As far as the centrifugal clutch, there's a puller made to take it off with, but I've never had to use one. I usually just tap the side of the clutch with a hammer hard enough to jar it and then take both hands and get hold of it and pull hard and it usually comes off. If that don't work for you, then you'll probably have to get a puller. I don't know if you've gotten the big nut that holds the clutch on loose yet, but if you haven't it has left-hand threads. To take it off, turn it clockwise. I use an air impact wrench to take it off.
