No not to bad, around 45 bucks for the cam chain,10 bucks for a valve cover gasket and 10 bucks for a left side gasket. pull the valve cover, pull the flywheel cover pull the flywheel take the cam chain sprocket bolts out ( don't forget to loosen the camchain tensioner) take the sprocket out of the way and remove the chain through the bottom where the flywheel was.
