Can anyone help me bypass my nuetral safety switch on a 96 trx300fw? I need it to start in any gear.Also when i do this is my nuetral light always going to be on? Thanks
The reverse light should still work. The neutral light sensor or switch is located at the bottom, right side of the engine, behind the foot peg. It is covered by a thin metal plate with one 8mm bolt holding it on. The picture below shows, both the neutral and reverse switch, without the metal plate covering them.Would you happen to know where the nuetral light sensor is?I don't mind the light being on all the time, but does the reverse light come on anymore?
Superhero. LMAO. That's the first time I've ever been called a superhero. I guess I've been called about everything but a superhero. LOL. Anyway, you're welcome.Thanks man, you just saved me from drowning in the future, so yes technically you are some sort of superhero. Seriously thanks for the help.
