2004 Honda Sportrax ex, replaced solenoid, battery, spark plug, ignition solenoid, has good power, when I try to start it, it only buzzes. Won't try to turn over. I checked fuses, all good, getting gas, don't know what else to try
Sounds like possibly a ground problem if you are certain you have good power at the starter( I would verify that first for sure) check your grounds or run the neg side of a set of jumper cables from the neg terminal to the motor near the starter or the starter casing itself. I would verify you have good connections at the battery and load test it if you haven't already new doesn't always guarantee good. Can you jump the terminals of the solenoid? That will bypass both the solenoid and the push button. If all else fails you can use jumper cables to run pos battery directly to the starter lug for a generic starter test.
