Hello all. Long time looker, first time poster. After some searching I've not found any info on my problem. I have a 06 rancher 350es. It will not shift. I can cycle the ignition switch and It will shift just once, then nothing. I can ride using my emergency shifter. All gears are operational. Also I do not have any display on my meter. It was fading months ago, then it went out. So I cant pull any codes off it. Is there a way to hook up a test light to the neutral gear wire to the meter so I can count the flashes during diagnostics mode?
Parts that were replaced.. all parts are honda oem.
Battery - old one had a bad cell
Shift switch on handle bar- replaced due to lights not working 2 months ago
Angle sensor just replaced. But I didnt reset ecm?
Any help will be appreciated
