says to rev over 2000 rpm for first 10-15minutes.is this in gear or neutral?
That won't make a difference. The piston and cam will be moving 2000rpm whether it is in gear or in nuetral. An air cooled motor might get warm without air moving across it. If you do it in nuetral place a fan in front of your quad pointing at the motor.
alright thanks.i ended up putting in neutral since its only 30 degrees today.waiting on baby momma to get home to test ride.
