1 - 10 of 10 Posts
The Braven Ironside with it's aggressive wraparound sidewall and rugged 8 ply rated radial construction, this tire is ready to concur the toughest trail!!!
Braven Ironside
Click here for online/mail order: Braven Ironside Availability and Pricing
Also available in store by special order: Store Locator
-KEY FEATURES-
  • Over-The-Shoulder Lugs & Sidewall Traction - design that wraps down the sidewall and adds extra strength & traction to the shoulder & sidewall areas.
  • Multi-Purpose Mad Traction Radial Tire - excellent stability and enhanced handling...AND....MAD TRACTION!
  • Chip & Tear resistant rubber compound - the proof is in the pudding...our tires are tough.
  • 8 Ply rated construction for strength and durability
  • Strategic voids - for easy clean-out and increased traction
  • Staggered Center Lugs - increase biting edges for improved extreme weather and off-road use while helping to reduce noise.
  • Rim Guards - gotta have ’em
  • Sipes - strategically placed for maximum traction
  • Staggered Shoulder lugs - increases your ability to attack!
  • Stone kicker bars - help to wiggle out any foreign matter buildup.
  • Smooth Riding
  • DOT for ATV/UTV Use Only!
-MEDIA-
what does this mean??
is there some sort of set rules that differ for, ATV "DOT" rules from car/truck "DOT "rules??
I mean some UTV go a 100 MPH, so are they speed rated and such??
as I never heard of any??
either a tire is street legal(DOT approved) or NOT
please explain if you can!
My guess would be a load rating difference. I'm interested to find out though.
Thanks for your question. Yes, there are differences in the testing procedures to become DOT rated for an ATV/UTV tire compared to a truck tire.
Tires that carry the DOT approval from the National Highway Traffic Safety Administration need to pass their testing procedures. If they do not pass the NHSTA validation testing they do not get to put DOT on the sidewall.
ATV/UTV tires also have load ratings and speed rating listed on the sidewall.
Hope this helps.
OK well that just opens more questions from me?>
what are the difference in ratings, as IMO< a DOT tire means its a street legal tire NO
so, if the ATV tire is DOT< rated
doesn't that lean its a street approved tire then or NOT
as if NOT whats the point of using the DOT name at all then??
seems miss leading??
as most NON street legal tires just DON"T add anything to them, but weight ratings & maybe and ply's?
as NO need to say NOT DOT approved, its sort of taken for granted no??
so, do you know what the ATV/UTV tire DOT rules are for the tires, and I have NEVER seen a SPEED rating on an ATV.UTV tire, can you show me any?/ or give an example of them??
Discussion Starter · #6 · (Edited)
A DOT ATV/UTV tire means it is legal to be ridden on the street. It has been certified by the National Highway Traffic Safety Administration. We do not have the certification rules as the manufacturer is the one that applies for DOT certification.
I can tell you the Braven Ironside 28/10R-14 for example, has a 77J load index/speed rating (AKA Service Description):
77=908 lb. load rating
J=62 MPH
Hope this helps.
I can tell you the Braven Ironside 28/10R-14 tire has a 77J load speed rating:
77=908 load rating
J=62 MPH
Hope this helps.
OK thanks, I looked on your site and didn;t see any spec's on them that was why I asked too
and yup, that was about what I was wondering about, what speed ratings they have
so to be honest and fair, these tires wouldn't be legal to use on road with speed limits over 60 mph then, or safe ?? ??
Considering many large sport UTV"S AT v's will break 62 mph without a sweat, makes one wonder ?? or wonder what NON DOT tires are rated at for speeds??
Do they make it in:
24x8-12
24x10-11
Lemme guess...probably not. I think these tires would be great for my riding...especially how much asphalt my tires see.
Reactions: _Wilson_
Discussion Starter · #9 ·
All of the tires will have the service description on the sidewall. ATV/UTV tires are ment for limited on road use, I do not believe they are intended for people to use on the road hat high speed.
Do they make it in:
24x8-12
24x10-11
Unfortunately they are not mad in the size you need at this time.
Here is a link to the sizes they currently make:
Braven Ironside | Discount Tire Direct
Discussion Starter · #10 · (Edited)
BRAVEN IRONSIDE | Moab Toughness Test
At this year’s Discount Tire Rally on the Rocks, we had a set of the 30x10.00R-14 Braven Ironside 8-ply rated tires on a RZR 900(4) to test at one of the toughest trail systems in the country. We also picked a rider to test them that is a legend for breaking parts and/or tires every year. We figured if the Braven Ironside could stand up to Eric's abuse, they would be an outstanding tire for anyone! Many of you know Eric as our resident announcer at the Discount Tire raffle at Rally on the Rocks. Eric displays just as much exuberance on the trails as he does on the stage.
The maiden ride with the new set of Braven tires was from the Spanish Trails Arena on the main asphalt road pulling our Trail Support Trailer over to the Kane Creek trail head for a trail restoration project with Tread Lightly! The Braven Ironside showed excellent road manners on the pavement and gravel road. They were smooth and had very little road noise. The sidewall provided a comfortable ride, while the staggered tread blocks found excellent traction with no pushing in the corners, even with the added weight of the trailer on the tight switchback gravel road.
Eric was able to deliver our trailer without any issues, which we used to feed all the volunteers after they completed building fences. There is nothing quite like being able to grill hot dogs and hamburgers after a successful Trail Restoration mission.
The next day we hit Moab Rim. This is a tough 7+ rated trail that tests the sturdiness of any tire. There are many steep ledges and large boulders you must go over as you manage your way along the steep trail.
Eric was amazed at the traction of The Braven Ironside at Devils crack. It is not uncommon to see riders use wheel speed to get over the sizable crack at the edge of the cliff. This time, with the traction of the Braven Ironside, Eric just crawled to the top with ease!
Next up was the Z-turn. Here we will typically see Side by Side riders start to the far left of the trail, and have to jockey the machine back and forth to get up this tough turn. This time, with a sense of confidence provided by the Braven Ironside, Eric was able to go up the steeper section, which is most commonly used by Jeep’s and built off-road rigs.
Coming back down the trail the tires showed exceptional holding power aided by the additional tire siping. The machine was in total control coming off the many drop offs.
With the added confidence in traction the Braven Ironside allowed Eric to tackle steeper obstacles, and every time his Ironside tires pulled through with flying colors.
Throughout the week, the many trails at Moab provided numerous terrains that we were able to test the Braven Ironside tires on. Two terrains that were noticeable to the genuine durability of the tires were in loose sand, and also extremely rocky trails. The Ironside always pulled the side by side around the corners without any push in the sand or rocky trails. The toughness of the tire with the extra deep rim guard was put to the test on the rocks as Eric punished them, but in the end they were no worse for wear.
The last obstacle for this year’s Discount Tire Rally on the Rocks was Tip Over Challenge, which is known for inducing butterflies in even the most hardened off-road rider, however, it turned out that it was no challenge for the Braven Ironside. Once again showing their superior traction and grip, Eric was able to descend the rock with ease, and confidence all while being in complete control.
After an amazing week at Discount Tire Rally on the Rocks, it was sometimes easy to forget that while we were having fun, we were also here to work. We inspected the Braven Ironside tires at the end of the trip. We rode over 300 miles on the street, gravel roads, hard-pack and of course rocks and ledges. We could not find any chunking or gashes in any of the tires. Eric said "The Braven Ironside tires exceeded my expectations on the extreme trails in Moab with their grip on the rocks and traction on hard-pack. I pushed the tires harder each day as my confidence in them grew. I had zero flats which is a bonus for me plus they were smooth and quiet on the road. I can't wait to get them on the desert trails around Arizona to continue to test them."
If you are looking for a tough all terrain UTV tire, be sure to take a hard look at The Braven Ironside at Discount Tire.
Search Braven Ironside by Size | Discount Tire Direct
1 - 10 of 10 Posts
