My new to me 2006 350 rear brake adjustments were turned all the way in, still working but time to replace brake shoes.
After getting the ATV up off the floor and removing the wheel. All I can say is I am glad I still had my air impact wrench. The large nut was a bugger to get off. I found the cover dented and have a new one on order.... after I painted it thinking I would need to reuse.
The shoes were pretty bad. The top one was rusted on the pivot so tight it would not move so the only real brake was the bottom shoe. I am also going to turn the drum in my metal lathe to remove the ridge. I will used high temp grease on all the pivot points when it goes back together.
I wonder how the cover got dented, the wheel has no marks?
