I apologize for the ignorance, but I just finished changing out the front and rear brakes on my '02 Foreman/Rubicon. As it says in the service manual once I have the rotor back on the front brakes, I'm suppose to remove the inspection plug and turn the tire until the adjustment knob is visible allowing you tighten and then slightly back down the brakes. With the ATV jacked up (with all four tires in the air) and in neutral, I was easily able to spin the front right tire to allow for the proper adjustment. The problem is the front left tire wouldn't spin freely until I removed the cotter pin and castle nut. After doing that, I would spin the rear left tire to get the inspection hole lined up. I checked for play in the wheel to see if it was an obvious bearing issue, but it's the same as the front right tire with extremely small to no play while moving from side to side. I also double checked the brakes weren't dragging on the rotor. I've never dealt with a bearing issue before and only know from other posts, like vehicles that if tire can move a little from side to side, the play in the tire indicates a bad bearing.
I also moved the other three tires (while jacked up) with everything attached, to verify they would move freely and observed if I turned one of the rear tires or the front right, the other tires would spin as well. Just wondering if anyone has any suggestions or am I missing something there as there isn't anything wrong?
