My 1990 honda fourtrax 300 has a different rear end put on. I'm not sure what it's from but the brakes were disconnected for year. I'm just took the brake drum apart look for part numbers and I got ASK A7-GG. I look up the part number but I'm still not sure what the rear end is from. Any ideas?
post a pic of the rear end, and the rear brake side. just guessing ?, someone installed a rear end from and old trx350 fourtrax.
Discussion Starter #3
O
thinking it's not because of the single shock. Maybe 85 trx250?
149963
149965
149966
Discussion Starter #5
yep, deff not a trx300fw rear brake set up, trx250 for sure. trx300's do not have a SRA ( solid rear axle ). trx300's are open axle cept the very center where hitch mounts.
thanks man im going to try and get the brakes working. found out pretty guick you need brakes lol
Looks like a 86-87 TRX or ATC250 rear end , these shoes should work for you 43120-KG4-003 and here is a list of other models that us the same shoes --- no longer available from Honda but easily found on the net
This Honda 43120-KG4-003 SHOE, RR. BRAKE (ASK) (SEE KIT P/N--END OF BLOCK) (NOT AVAILABLE) Not Available fits the following models and components:
Honda Motorcycle Models with no year CB360T A Rear Brake / Panel
Honda Motorcycle Models with no year CB360 A Rear Brake / Panel
Honda Motorcycle Models with no year CB350K3 A Rear Brake / Panel
Honda Motorcycle Models with no year CB350K2 A Rear Brake / Panel
Honda Motorcycle 1976 CB360T A Rear Brake / Panel
Honda Motorcycle 1977 CJ360T A Rear Brake / Panel
Honda Motorcycle Models with no year CL350K2 A Rear Brake / Panel
Honda Motorcycle Models with no year CB350 A Rear Brake / Panel
Honda ATV 1988 TRX300FW A - FOURTRAX Rear Brake / Panel
Honda ATV 1988 TRX300 A - FOURTRAX 300 Rear Brake / Panel
Honda ATV 1987 ATC250ES A - BIG RED Rear Brake / Panel
Honda ATV 1987 ATC250SX A Rear Brake / Panel
Honda ATV 1985 ATC250SX A Rear Brake / Panel
Honda ATV 1987 TRX250 A - FOURTRAX 250 Rear Brake / Panel
Honda ATV 1989 TRX300 A - FOURTRAX 300 Rear Brake / Panel
Honda ATV 1986 TRX250 A - FOURTRAX 250 Rear Brake / Panel
Honda ATV 1985 TRX250 A - FOURTRAX 250 Rear Brake / Panel
Honda ATV 1986 ATC250SX A Rear Brake / Panel
Honda Motorcycle Models with no year CB350G A Rear Brake / Panel
Honda Motorcycle Models with no year CB360G A Rear Brake / Panel
Honda Motorcycle Models with no year CB350K4 A Rear Brake / Panel
Honda Motorcycle 1976 CJ360T A Rear Brake / Panel
Honda Motorcycle Models with no year CL350 A Rear Brake / Panel
Honda Motorcycle Models with no year CL350K4 A Rear Brake / Panel
Honda ATV 1986 ATC250ES A - BIG RED Rear Brake / Panel
Honda ATV 1985 ATC250ES A - BIG RED Rear Brake / Panel
Honda Motorcycle Models with no year CL350K5 A Rear Brake / Panel
Honda Motorcycle Models with no year CL350K3 A Rear Brake / Panel
Honda Motorcycle Models with no year CB350F1 A REAR BRAKE PEDAL + PANEL
Honda Motorcycle Models with no year CB350F A REAR BRAKE PEDAL + PANEL
Honda Motorcycle Models with no year CL360K1 A Rear Wheel
Honda Motorcycle Models with no year SL350 A Rear Wheel
Honda Motorcycle Models with no year CL360 A Rear Wheel
Check out atv.honda.com
Discussion Starter #7
Thanks man I'll take a look at those once I get it running.
