1 - 2 of 2 Posts
Ok so i have a 1985 honda trx 250 fourtrax and i had to take the brake lines off to weld a spot on my frame and im having a really hard time trying to get the brake cable holder back on the slotted nut on the backside of the rear brake any tips tricks or knowledge would really be helpful thank you in advance
Ok so i have a 1985 honda trx 250 fourtrax and i had to take the brake lines off to weld a spot on my frame and im having a really hard time trying to get the brake cable holder back on the slotted nut on the backside of the rear brake any tips tricks or knowledge would really be helpful thank you in advance View attachment 149869
take a flat blade screw driver, wedge it between the bracket lips at slot, spread it apart a tad, make sure to line the dots that are stamped on the bracket and cam end !. while your doing this, press/hold the cam outwards while sliding bracket back on, all while lining the dots up. easy. get to stumped ?, you can find us over here ---> www.atvhonda.com
1 - 2 of 2 Posts
