Hey guys. I need a little help fixing an issue. I have a 2006 TRX450R. I use it to trail ride. It always starts up. When I go over hills or turns that lean the quad it wants to bog down. If i nurse the throttle it eventually catches up. When I hit the throttle hard, it hesitates, only in 1st gear, then takes off. It also has a slight ticking sound. I have cleaned the carb and changed the plug and it still has the same issue. Any ideas on what else it could be?
