Agree, try to go up one size on the main jet, maybe 2. It is easy, on the very bottom of your carb there is a 17mm bolt. Remove that(gas will drain, so be prepared) then get a 6mm deep socket and put it up that hole that the 17mm plugged. The only thing you will be able to grab is the main jet. Remove that and change it. The needle jet holder might come out with it but not a big deal. Just swap out the jet and put it all back in there. Just finger tighten everything with the socket. These are made of brass and can break easy.
