I put a 20amp in instead on a 10amp now it will start but the throttle cable gets so hot it’s melting the plastic cover. So something is shorting thru it I changed the carb out a year ago with a China one I don’t know
unplug the bowl heater on the carb and i bet tht fixes your problem i had that happen on a shitty china carb on a rancher,its not really needed anywaysI put a 20amp in instead on a 10amp now it will start but the throttle cable gets so hot it’s melting the plastic cover. So something is shorting thru it I changed the carb out a year ago with a China one I don’t know
agreed!! ive never had anything run right with oneChina parts will ALWAYS cause an issue.. It's mentioned SO MANY times in this forum!!
Get online and search powersportsnation.com, buy yourself a good used OEM Keihin carb and be done.
Drop kick that China carb as far away as you possibly can!!
