1 - 19 of 19 Posts
All of a sudden the bike quit running. I found the main fuse (30 amp) blown. I replaced it but it lasted only seconds after starting it. I checked for obvious shorts such as frayed wires or loose connections and found none, can anyone help.
Welcome to the forums. You may have a bad regulator/rectifier. The hot wire runs through the main fuse and then to the regulator/rectifier and on through the keyswitch and back to the sub fuses. It also runs from the keyswitch to the display, speed sensor, and ECU.
Not sure on these but on an outboard you can check the continuity. It should only go one way. Put a VOM meter on ohms and put the leads to both wires and then swap. You should only get a reading on one. If you get a reading both ways or neither way it is bad.
i don't see how a bad reg/rec will cause a fuse to blow ?..the purphase of the reg/rec is too only recharge the battery and supply power to the lights and so forth..if the reg/rec went out..the only thing i know of..is it will not recharge the battery..and all the power will drain from the battery...once that is gone..then all the power comes from the stator..and if the reg/rec doesn't get replaced..this could cause the stator to burn out soone or later. fuses blow because there is a direct short to ground..means..there is a hot wire somewhere on the wire harness that is touching bare metal.
Yes, Shadetree, I know what a regulator/rectifier does. They can short out on the inside and cause the fuse to blow. I've seen it happen quiet a bit.
i never have..not saying it won't happen..lol.
Keep working on ATVs and you will eventually see it. LOL.
Evidently not. LOL.
bahhhhhhh..you just have worse luck than me !..lol.
Yeah, that could be. LOL. I've seen it happen probably 2 or 3 times, and if I remember right, twice on a 350 Rancher and once on a 450 Foreman.
all the more reason i'm trying to sell this 2000 trx350tm rancher..lol. i hate them..i'm old school all the way when it comes to a honda..i know the new hondas can't hold a candle to the old ones ..spec the trx300's !.
This just happened to me on my '03 TRX350FM yesterday. I started smelling something electrical getting hot and all of the sudden everything died. Check the fuse panel and the main 30 amp fuse had blown. I replaced the fuse and it started right up, moved about 3 ft and the new fuse blew.
I started searching for a short with my Fluke meter, but when I got back to the rectifier I could smell that it was burned.
Pulled the plug on the rectifier and put another fuse in it, fired right up and ran perfect.
I ordered a new rectifier, but I'm a little worried that something else may have caused the original one to burn. I guess it could have been overworked from the previous owner that had some sort of winch on the front. I've just learned from the A/C tech business that changing parts blindly can end up being costly, I always prefer to trouble shoot and diagnose what caused the failure.....especially with a $70 part.
I ohmed out the three yellow wires from the alternator/stator (at the rectifier plug) and they ohmed out fine, also checked them to make sure they hadn't gone to ground. I started it and the output voltage was around 18vac on all three yellow wires at the rectifier plug (between each leg to ground). The only thing that worries me a little is that I've read that the AC voltage from the alternator should be in the 30vac range?
Anyone know what voltage range I should be seeing from the three yellow wires off the alternator windings at the rectifier plug?
Thanks.
*EDIT - I went ahead and plugged the new rectifier in and all is good.
Exact same story, kept blowing main fuse. Pulled rectifier plug, fuse stop blowing. Ordered rectifier, changed in 5 min. Runs like new, no more blown main fuse. Thanks to this forum for great info.
Welcome to da forums...:icon_ devil: Glad we could be of some useful assistance.... ;)
TRUST ME!!!! The regulator can blow the fuse!! I spent almost 2 weeks trying to find my prob tearing my wire harness apart and tried everything and found out at the end after frying my computer that it was my regulator!
1 - 19 of 19 Posts
