Well I came across an offer I couldn’t pass up, a some what running big red for $450. Went and got it, no spark, no kick start, needed a lot of work and was a bit rougher than the pics in the ad. But it came with two totes loaded with old parts.
First thing I did was strip it down and pull off the wiring harness, and tore all the crap off of it. Man it was hacked. I replaced 25% of it with all new plugs and wire loom. Putting it back together has proven to be a challenge because it wasn’t all hooked up when I got it. I don’t have bulbs for the dash but jumping the solenoid bumps the starter so I’m making progress there, and 1/2 the harness isn’t hooked up.
It wouldn’t go into gear. He had both side covers off, and bolts missing from both. I removed both of them, realigned the shifter on the stator side, and stripped off the silicone from the clutch side. It shifts though the gears now without the covers on but I still can’t get the rear end to spin. Waiting on gaskets to put them back on, maybe with the old EPI stall kit out of my junkyarded grey 380 build.
I sand blasted the battery box and painted it gloss black, it needs a new battery cushion but I’ll wait on that. Luckily the battery is hot.
This thing is begging to be 300 swapped with a 317 kit, but I’d like to get the 250 running ASAP because I need a machine for snow season this spring. I have a 300 2wd engine to put it but it doesn’t pull and it smokes, so maybe I’ll get a little custom with that.
