1 - 18 of 18 Posts
i don't know..but if ya have a repair manual..it should tell you.
Get one with high cranking amps.It will endure cold starts much better.
i just put a brand new everstart in mine..it has 200 cca..it does my trx350d justice..soo..i'm happy.
The one I looked at came out of a 300 ex Its a not a very good battery. Low on power. Cheapo I paid $20.00 for it LOL
for a walmart battery..mine sure wasn't cheap...lol..it ate a 100 bill up quick..lmao.
I have nothing to say.I don't wanna start something again.
Agree^^^^^^^^!!
Yeah, get the biggest amperage battery that you can get that will fit.
lawn mower batt. are not designed to take the rough ride. Atv batt. are usally gel cells. If you were to use a lawnmower batt. you would most likely wind up with a leaking batt.
Oh and lawnmower batt. are not usally sealed.
You should be able to find 4-wheeler batteries at Walmart starting at $30-$40. It probably won't be the exact one you're supposed to use in your 4-wheeler, but they will work as long as it will fit and the terminal posts are on the correct side, so that the cables will reach. That is, if you want to shop at Walmart. Sorry, Billy.
You ought to be.:mad:
1 - 18 of 18 Posts
