OK guys, what make/model tenders do you all use
I am debating on using them again after having two of them fail on me and one causing me a lot of issue's and costs when it over charged a shid steer it was hooked up to, and then second one I THINK I caught before it screwed up a second machine!
BOTH tenders were bought at same time, less than a yr old and were both Schumacher model SEM-1562A-CA
I actually bought 5 of them on sale at Tractor supply store, and stopped using the others due to well, paranoid I guess of them, almost a several hundred bucks down on repairs on machine due to it over charging and cooking things before it failed and stopped working!(tender that is, machine was parked when it went bonkers)
when I first discovered thing wrong, I contacted Schumacher, as they were all under warranty, and at FIRST they were all understanding and offering possible help with repair costs, but then after that, they have refused to even return a phone call and or email, so I am very turned off by there BS story they gave me on the first contact and stopped contacting me after that more or less! or once I told them the first set of things that needed replacing and there cost.
they magically just stopped responding with me, no excuse no NOTHING< just will not return a call or email, as ALL I get when I call them is directed to the person 's extension and put on hold and then voice mail! and again Emails get NO reply's!
so am NOT very impressed with there customer service, and doubt I will be buying any more of there products, !
SO< what are you all using, do you ALL use maintainers with IN line fuses to help protect things?the model above DIDN"T have a inline fuse, and think MAYBE it should have? might have helped me but not sure
I have seen one's with in line fuses and the fuses seem to range a in a lot of sizes, from 3 amp to 25 am fuses in them, so not sure where they should be at, to prevent a like repeat on things IF a tender ever fails again like mine did (two fo them so far) LOL
SO< what are you all using, , how long, and have any issue's with the,?
