Easiest way is to find a socket that fits over the boot and catches the steel lip or use a piece of steel tube. Suppose you could use box section too. I always clean the hubs throughly and apply a light coat of grease or oil for ease of fitment.
Reactions: _Wilson_
Getting them out is easy , putting them in without doing damage to them is not , like Sam mentioned , clean the bore before attempting to install , I like a Dremel with a sanding drum , don't take off too much and make them fit loose
I've dropped certain types bearings and races in the deep freeze, never thought to try that with upper and lower ball joints, altho.... With the temp standing @ 18 degrees outside.... you wouldn't need a freezer today...lol
fish..... Looks like you had some stinging pest build up under the left fender.
Reactions: fishfiles
That is a nice nest , seen them much bigger , that is a old pic -----on heavy equipment I have used dry ice to freeze bushings and use a rose bud to heat the housings/bores before installing
