Still having issues with trx250a carb... replaced the float, replaced the jet for an OEM which cured it temporarily but I still get a leak once I stop and the ATV is ticking over.
I can't find a second hand OEM carb anywhere and I'll be damned if I'm buying a Chinese knock off. Will an ATC250ES carb fit straight up to the TRX250 inlet rubber? The top of the carb is screw type on the ATC so I assume I'd just run an ATC throttle cable?
