Hi I’m having trouble with my atc I got a month ago I got a second one that came with a rebuilt motor I put the rebuilt motor into my good one and now it won’t start it has spark good compression and fuel air filter isn’t plugged either I did the timing on it as well it just won’t fire for the life of it anyone have any ideas what it could be? Thanks
make sure that there is gasoline in the tank. Next, check the oil level and make sure it is full. If the oil level is low, add oil until it reaches the full line. Finally, check the spark plug and replace it if it is dirty or damaged.
I put a new plug in changed the oil and still no luck the spark looks weaker than it did before but it does have spark sprayed gas into carb and still no luck with it running
