Hi, i have an 01, 350 rancher FE and the frame is getting bad along with a few other things, the engine is great and i was looking to get a blown up bike and put all the good parts on one. I was just wanting to know if the frames are the same for the different sizes, thanks
None of those are the same as the other. All different. Th 400/450 frames are close to eachother but still different in some ways. 350 frames are unique to the 350, and the 300 frames are unique to the 300.
IIRC the 350 frames are close enough that you can use either 2wd or 4wd / ES or S doesn't matter. I think shade had said the 2wd frames have the diff mounts without the nuts welded on, but that was the only difference. Can always check P/N's.
