rincon 04
2yrs ago i had Lucile overheat on me ( red light come on ) and shes been running hot ever since.
That day2 yrs ago i pulled the plastic and pull the oil cooler ( pluged solid) cleaned it out.
Here i am last week clean the rad water/air drained flushed and put in engine-ice, spaced the oil cooler out 1/2.
I let her come up to temp with the cap off probing the upper hose rad and lower hose got to 200 on the rad.
so at this point the T-stat should be open. BUt i can't see any flow in the rad.
I shut her off let her cool add more coolant same test with the cap on.
190 on Tstat hose 200 rad 180 lower hose. fan came on turn off. i was like ok looks good for now.
went riding Sunday for 4hr NO problems till on the way back the fan was coming on and just staying on 5min+ I stopped shut her done and just let her cool off did this twice on the way home just to be safe.
Got home washed her out ( yes lots of mud all over the atv) but really did not get anything out of the rad. Was in a few clean water basins also ( deep)
Im gonna pull the T-stat tonight test it + order a water temp gauge
MY only real ? is dose the water pumps on the rincon flow enough to see it in the rad circulating ?
